HEY STEVE OR 1020 OWNER
MARK IN MO.
10-18-2003 00:41:17
I AM LOOKING FOR SOME PICTURES OF A JD 1020 TRACTOR IN GOOD CONDITION. I WOULD LIKE SOME TAKEN IN HIGH RESOLUTION IF AT ALL POSSIBLE.
MINES NOT PAINTED YET AND NEED FOR REFERENCE AND TO PRINT AND FRAME.
THANK YOU
MARK
STILL LOVING MY 1020 GAS W\143 LOADER
harold bankston
10-21-2003 19:35:13
 Re: HEY STEVE OR 1020 OWNER in reply to MARK IN MO., 10-18-2003 00:41:17
I HAVE A PRETTY GOOD STORY ON MY 1020 MY DAD BOUGHT BACK IN 1971 THEN SOLD IT IN 1976 THEN BOUGHT IT BACK IN 1980 AND WE STILL HAVE IT THE ONLY PROBLEMS WE HAVE HAD IS THE POWER STEERING WHICH JUST WENT OUT ITS NOT AS GOOD LOOKING AS IT ONCE WAS BUT IT'S STILL NOT TO BAD I HAVE RECENTLY THOUGHT ABOUT SELLING IT FOR A BIGGER TRACTOR BUT JUST CAN'T GET RID OF IT
Frank in Wv
10-18-2003 07:01:41
Mark in MO.
Send me your email address. I have an original 1020 Diesel that may help with pictures. Email me at work [email protected] or [email protected]
I have some various picutres of the 1020.
Frank in Wheeling
MARK IN MO.
10-18-2003 12:27:28
 Re: Re: HEY STEVE OR 1020 OWNER in reply to Frank in Wv, 10-18-2003 07:01:41
THAT WOULD BE WONDERFUL!!!
I WOULD REALLY APPRECIATE ANY AND ALL HIGH RES PIX YOU CAN SEND.
THANKS YOU IN ADVANCE
MARK
REMOVE NOMAIL TO EMAIL ME
Steve - IN
10-18-2003 05:55:14
Mark,
Good to hear from you. I take it all the mechanical woes on your 1020 are cured. Super! I could send you tons of pictures of mine, but there are a lot of details that aren't exact. For example: I ran the yellow stripe on mine all the way all the way back to the dash - the original only went to the rear of the hood - but the replacement decal was long enough, and I liked the way it looked.
third party image
Here's a 1020 from the photo gallery here which looks good, but the stripe isn't as long as mine originally was. His is a '68, mine is a '66. Who knows, they might both be right. third party image
I found this photo on the web, which shows the side stripe at the length mine was before I repainted it.
third party image
Probably the best place to get a bunch of orignial pictures like this from an old catalog or brochure. And guess what, you're in luck - there's one for sale right now on eBay. The bid is ~5 bucks and the guy wants 3 bucks in postage. Here's the link for the item. A few other things that gave me problems: the 143 decal on the upright for the loader and the front medallion. I finally found a custom decal website like this one and selected Eurostyle bold face, but clipped the ascending serif off the "1", and here's how it turned out.
third party image
The yellow is a bit weak, but not too bad. The real problem is the decal store also sold pin striping -- and as you can see, I had waaaay too much fun with yellow pin stripes. Definately not original or correct!
A few things I've never found are the shift pattern decal and the correct size black/silver JD decal on the dash. If yours are half way decent, tape over them before you paint. The medallion in front is fairly rare. I solved that problem two ways: I found a 4 legged deere decal, hot melted clear plastic over the oringinal embossed center, then applied the decal to the plastic and trimmed the slight bit of excess. I later found a pristine medallion at a Portland show, bought it, put it on the shelf and left the old decal faced one on to get beat up. Another thing you'll almost certainly need is the clear plastic hub cover on the steering wheel. There's a guy in southern Indiana who is making them. Can't find his website right now but know they sell his product at K&K tractors in Shelbyville, IN.
The only other odd thing I know of is that on mine, the round ended 3pt adjuster lever was originally painted yellow from the factory. Otherwise, real simple. The sheetmetal is all green (and you get to choose if you use classic green or newgen green), the wheels are yellow, and the dash and the vertical sheetmetal piece under the dash are a semi gloss black. A JD dealer has all three paints, and if you use hardener with them - beg, borrow or buy a fresh air respirator to use when you spray. I borrowed one, and am happy to report I could still move the following morning.
All I can think of for now. Good luck with the project. Let me know if you need to ever pick my feeble brain again.
Steve
MARK IN MO.
10-18-2003 12:40:00
 Re: Re: HEY STEVE OR 1020 OWNER in reply to Steve - IN, 10-18-2003 05:55:14
THANKS STEVE. YES ALL IS CURED. FUNNY THING THOUGH, ALL THE PROBLEMS WITH THE TRACTOR WERE THINGS THAT WERE DONE BY THE PREVIOUS OWNER. GO FIGURE. THE TRACTOR RUNS PERFECT BUT ONE THING I STILL HAVE TO DO NEXT YEAR IS TEAR IT DOWN AND REMOVE THE CRANKSHAFT AND HAVE IT GROUND, THERE'S A ROD KNOCKING AND IT REALLY SOUNDS BAD AT STARTUP. I HAVE REPLACED THE BEARINGS BUT ONE OF THEM WAS SPUN BEFORE I REPLACED THEM. ALL THE HYDRAULICS WORK GREAT AFTER REPLACING THE FLUID WITH JD HY-GUARD [SP]. I WILL PROBABLY REPACE THE CLUTCH AND THE RING GEAR AT THE SAME TIME BECAUSE IF YOU REMEMBER IT WAS SPINNNING ON THE FLYWHEEL AND WOULDN'T START THE TRACTOR WHEN I FIRST GOT IT. THE PREVIOUS OWNERS WERE MORONS.
THE GOOD THING ABOUT ALL THE PROBLEMS IS THAT I KNOW THIS TRACTOR INSIDE AND OUT NOW. I THINK THAT'S A GOOD THING.
THANKS AGAIN STEVE
MARK
Steve - IN
10-18-2003 15:27:20
 Re: Re: Re: HEY STEVE OR 1020 OWNER in reply to MARK IN MO., 10-18-2003 12:40:00
Mark,
Yes, it surely is YOUR tractor now that you've been completely through it. That, from my experience, is a real source of pride.
Sure do remember us writing back and forth about about the starter problem. I think I was the goofy guy who said if every thing else checks out, it must be the ring gear turning on the flywheel. Sounded kind of impossible to me at the time as well.
I've got an article from a JD magazine that Stan - FL was kind enough to send me. If you don't mind big files coming in, I'll send it along to you. Also, I do have a fair number of pictures in the 600 to 1200 dpi range. Is that high enough res for you? Let me know...
Steve
MARK IN MO.
10-18-2003 22:34:08
 Re: Re: Re: Re: HEY STEVE OR 1020 OWNER in reply to Steve - IN, 10-18-2003 15:27:20
THOSE WOULD BE GREAT.
THANK YOU
MARK
Bruce L
10-18-2003 11:02:46
Steve, I was just wondering what method you use to post multiple pictures?
Steve - IN
10-18-2003 12:18:45
 Re: Re: Re: HEY STEVE OR 1020 OWNER in reply to Bruce L, 10-18-2003 11:02:46
Bruce,
Fairly simple, the posting box here will accept and store html markup language. So you're basically just making a little web page. Just start your post like this:
bracket html bracket
(I can't type the actual bracket here or it would start reading it as a web page, but they're the great than, less than signs that are above the comma and period on your keyboard.)
Next type text -- blah blah blah. Then insert picture like so -
bracket img src=http://www.mysite.com/mypicture.jpg bracket
Type more text, blah, blah, blah. Insert next picture like so -
bracket img src=http://www.mysite.com/mypicture2.jpg bracket
more text here, and so on.
Then at the end, you type bracket /html bracket and you're done. If you want, you cold use different size and color fonts, gif animations, play midi songs, have pop up ads and other java scripts that would just generally annoy the heck out of everybody!
Have fun!
TG
10-18-2003 05:24:43
third party image
Down the left column on this page is "Galleries" and Tractor Photos. Search for "1020" and you will find several. I get great enjoyment from using this tractor.
Steve - IN
10-18-2003 06:03:28
 Re: Re: HEY STEVE OR 1020 OWNER in reply to TG, 10-18-2003 05:24:43
TG,
Looks like I borrowed your picture. Didn't know you'd posted until after I'd pressed the button.
Where's you get that hood decal? It's shorter than the one that was originally on my '66 1020, and looks more like something on a 2020 / 3020 / 4020. And it's surely not like the aftermarket decal I got for my 1020.
As you can see above, I'm obviously in no position to throw stones about originality - so don't infer that from my comment. Main thing is we enjoy those sweet little 1020's.
TG
10-18-2003 19:11:39
 Re: Re: Re: HEY STEVE OR 1020 OWNER in reply to Steve - IN, 10-18-2003 06:03:28
That is the decals that was on it when I bought it a couple of months ago. I've been too busy using it to check the originality and start any restoration.
No problems with the comment or photo use. I'm glad to see some good discussion about this great little model.
