Timing my 730 LPG
Ben.So.Tex
09-09-2002 19:36:54
Am I doing this right? Bring left piston to compression stroke,,,Move flywheel to 5 degree pass TDC,,, Now I go around to the dist and turn it till the points open... Tractor should be in time? RIGHT or WRONG. Thanks Ben..
DON
09-10-2002 12:14:04
 Re: Timing my 730 LPG in reply to Ben.So.Tex, 09-09-2002 19:36:54
Set the timming at wide open throttle and 15 degrees if I remember correctly, 730 gas was 20 degrees but the LP is 15 degrees. If I remember the plug gap is .015 . Don
