Need To Know ASAP: Piston to Cylinder Wall Clearance
Aaron
09-09-2002 19:08:17
hi, I am installing new .045 Aluminum Pistons in a 52 John Deere B. Can some one tell me what the Piston to
cylinder wall clearance is or is it the smae as the cast pistons. Thanks Aaron
Gpower
09-09-2002 19:17:50
 Re: Need To Know ASAP: Piston to Cylinder Wall Clearance in reply to Aaron, 09-09-2002 19:08:17
5 to 9 thousanths
Gman
09-10-2002 04:01:45
 Re: Re: Need To Know ASAP: Piston to Cylinder Wall Clearance in reply to Gpower, 09-09-2002 19:17:50
Aaron if you are installing new or aluiume pistons they require more clearance than cast iron pistons. I installed a set of Henrick pistons in my "G" and he recommended ten thousands piston to wall clearance. It would not hurt to check with your piston supplyer for proper clearance. On my puller I got a set of big fat pistons and I run 18 thousands clearance and I think they still create more drag by swelling,thus dragging the horsepower down.I would give at least 10 thousands clearance on regular alunium pistons. Gman
