46JD-H questions
Zeb
09-09-2002 17:55:56
My cover on top of the crankcase was leaking oil so I made a new one out of gasket material and it still leaks. Should I just use a gasket sealer with it or could there be something else wrong also? Could this also cause low oil pressure? Another problem is when the pto shaft is engauged I can grab a hold of it and stop it, must not really be engauged.Any ideas what it might be before I just tear into it? Thanks
dan_41jdh
09-10-2002 05:00:20
 Re: 46JD-H questions in reply to Zeb, 09-09-2002 17:55:56
Zeb,
Perhaps your crankcase cover is slightly distorted because of overtightening. Check it against a flat surface, maybe the local areas around the bolt holes are bent down, which keeps the gasket between the bolts from being properly compressed. If so, you can straighten the bolting flange surface with a little hammering using a flat steel bar as a backup.
I can't remember if the bolt holes in the case for that cover are blind holes or if they are through holes. If they are through holes, you should use sealant on the threads to prevent oil seepage along the threads. This has nothing to do with low oil pressure. Oil pressure can be adjusted, if necessary, by the pressure adjustment screw on the side of the pump (accessed through a pipe plug hole on the side of the main case). Low oil pressure may also be the result of excessive wear.
Its pretty common to see the PTO shaft on an "H" rotating if the clutch is engaged, even though the PTO is disengaged. The thick transmission oil sort of "drags" the PTO drive gear along, as things are turning inside. Usually, this can be stopped by installing a new outer oil seal, which adds just enough friction to prevent the PTO from turning.
leon
09-09-2002 19:02:49
Zeb, I don't want to sound undully harsh, but I would wonder more about what's wrong with a guy who would grab hold of an engaged, turing PTO shaft than I would wonder about what's wrong with the tractor. PTO's are really dangerous, even on a 14 hp tractor! If it had been working, you would never been able to let go. At best your arm would habe been broken is several places! Let's all keep in mind that our toys can hurt us if we don't give them the respect they deserve. Besides, from personal experience, I know that it takes at least two good arms and hands to work on an H. Good luck with yours.
