Antique jd plow
Tracy in ND
09-09-2002 16:07:40
I recently acquired a JD 2 bottom 14'' plow. On top of the draw bar there is a spring loaded adjustment that appears to change the pitch of the entire plow by turning a crank. I am not talking about the spring loaded trip on the main draw bar. I have never seen this before, so can someone tell me if this adusts for different draw bar heights on the tractor? Does this need to be adjusted every time you go out in the field? Also, I noticed the "sissy wheel'' in the rear of the plow is stationery. Thanks for any info you guys can offer.
Tracy in ND
Ron in MN
09-09-2002 19:14:05
 Re: antique jd plow in reply to Tracy in ND, 09-09-2002 16:07:40
Tracy, That sounds like the same plow I have. Mine is a 44H. The "sissy" wheel at the rear is completely off the ground when the plow is in transport position and the spring mechanism you refer to is what keeps it steady when out of the ground. According to the operator's manual, that hitch rod "lifts the rear end of the plow for transport and maintains a constant pressure on the rear bottom of the plow when plowing". It does not need to be adjusted each time you go to the field. Both operator and parts manuals are still available from Deere to give you much more information
