John Deere B Cam Position
G.Rainey
09-08-2002 18:59:14
WTW or Clooney or anybody,I have a '38 U/S B put on a n.o.s. block new rings regound cam ground valves engine good shape but no power? When I put the cam in is it possible to get the cam out of position,there is three holes and I beleive they all will line up and I got it off by 60 deg. is that possible? I've when over the crank and timing gear marks several times,adjust the mag. still acts like it is running in a strain and temp gets a little higher than I think it should without load. If it is the cam that is off how do you get it in the correct position,I removed the crank cover and looked at the position my "G" cam was in with marks lined up when I put the cam in. Any ideas or help will be greatly appreciated this B has been a pain to get running to suit me. I built me a 952 wagon gear parade wagon and the B is ideal size to pull it but it doesn't have the power. Later Garland
WTW
09-09-2002 11:15:34
 Re: John Deere B Cam Position in reply to G.Rainey, 09-08-2002 18:59:14
Garland, I will sum up some of the good information already given and add just a little more. The first thing that comes to mind with your situation was what Clooney hit on, that being you have drag do to mechanical interferences. As he said check it out by removing the spark plugs and turning the engine over by hand. Do this when the engine is hot to check for piston / cylinder wall interferences. The next thing that comes to mind was timing as Mike hit on. Check governor timing as he suggested and when you have the governor timed right, drive flange horizontal when engine is on top dead center, check mag mounting angle when you time the mag to the engine. If you find that the mag has to be rotated allot to get it to fire at the correct starting position (impulses when flywheel is at LH Impulse mark) this would lead me to think that the lag setting is way off on your mag and in turn causing you to incorrectly time the mag to the engine. If you have not had the lag timing set or checked on the mag I would do so. The correct lag is 35 degrees advanced. I have seen many mags set where the timing is as far advanced as 50 degrees and many in between. This adjustment will not effect how the tractor will start so much as it will effect how it will run and power it will produce. The best way to have this set is on a mag bench with a protractor if you want it 100% percent accurate. The old service manuals will give you some guidelines like two and half marks which will get you in the ball park but does not allow for wear and imperfection every mag has. If you want it run and set let me know as I have a mag bench to do so. Doest take that long to do if there is nothing else wrong with your mag. If you want to tinker with it yourself you can degree the flywheel out and use a timing light to see where it is at. I do not think it is cam timing as the timing gear will only bolt on one way. Check cam timing as Paul suggested also to verify. Good Luck, Dave W.
Garland
09-09-2002 19:06:11
 Re: Re: John Deere B Cam Position in reply to WTW, 09-09-2002 11:15:34
Dave thanks for the comeback I new you pull and work on B's and you could get this thing lined out. To make sure the the flywheel is on correct with the left hand-Exhaust should be aligning with mark on case and left hand exh. valve starting to open is that correct. My son got to messing with mag and and set the marks to "0" I no this is incorrect it should be on 35 deg.adv. but the darn thing runs this way and I put a timing light on it andmark on flywheel and case align,but it doesn't have any power and gets hot. I'm inclined to think the flywheel is off one spline even though the punch marks line up on crank and flywheel.Give me some pointer making sure the flywheel is in correct position,I've never had a problem like this and I work on a lot "G"'s and a puller but this little old B is about to do my patience in. Thanks Gman
WTW
09-10-2002 08:48:19
 Re: Re: Re: John Deere B Cam Position in reply to Garland, 09-09-2002 19:06:11
Gman, I would check the flywheel to crank position first. The LH Impulse mark (Not the LH Exhaust) is the top dead center reference mark when it is aligned with the transmission side cover corner. To check for correct flywheel position, remove the No. 1 sparkplug on the flywheel side, rotate engine until you can see the piston at the very top of its stroke through the sparkplug hole, rock the flywheel back and forth where you can see the piston move up and down and center the piston in the middle of this movement. The LH impulse mark should align with the transmission cover edge. If it is off even one spline it will not even be close. If you have the flywheel off you will see that one of the crankshaft splines has a drilled and tapped hole in the edge of it. There is supposed to be a tall headed 1/4" screw in it to index in one special spline in the flywheel. This makes flywheel timing Goof Proof if this screw is kept in place. Once you have determined it is, then you can take a carpenters square from the LH impulse mark and the center of the crank and chalk yourself a 90 degree reference mark (Counterclockwise / before LH impulse) on the rim of the flywheel. With a piece of string measure the distance from your TDC reference (LH Impulse mark) and the new 90 dgree mark and divide it in half making another mark between the first two This mark will be the 45 degree mark, again measure from the TDC mark to your new 45 degree mark and split the distance again and make another mark in between them, the new mark will be at 22 1/2 degree's. Now that you have your flywheel degreed out at TDC (LH Impulse mark) 22 1/2, 45 and 90 degree's put the timing light on it and see just where it is running at. Should be in the 35 degree range or a little less. If close your tractor should run just fine. This is a crude way to see where the lag setting is at on your mag without having it on a bench. It is very accurate and simple to do if you have a common timing light, carpenters square and a piece of string. Let me know what you find Good Luck, Dave W.
Clooney
09-09-2002 03:24:55
Garland, Mike & Paul pretty well covered it. Make sure the flywheel is on correctly, if it is off a spline, both the cam timing & mag timing will be incorrect if you used the flywheel marks to set or check them.
~How easy does it turn over by hand with the plugs out? If it feels tight maybe you have a tight bearing.
~One last thought: I had an "A" act like yours years ago [but it also started hard] & it turned out to be the mag, if it has a Wico C & you had the cover off, make sure you didn't bend the little contact between the cap & coil. If that is bent & leaving a gap [not making contact] it will spark enough to start it but not enough spark to fire good under load. Take an old spark plug & open the gap to 1/4" then see if your mag will produce a BLUE spark [multiple times in a row] across that gap, on both wires..... ..
Garland
09-09-2002 10:44:48
 Re: Re: John Deere B Cam Position in reply to Clooney, 09-09-2002 03:24:55
Hello Mr. Clooney thanks for the reply,If the Left-hand exh. valve just starts to open the (L.H.Exhaust mark) should be aligning with mark on case right. I'll double check this I didn't have flywheel off but it has been off because it is punch marked. The mag should be firing when the ( Left-hand Impulse aligns with mark on case) and the mag slot should be horizontial at this time. I'll make another stab at this critter and let you know what I find. Gman
Clooney
09-10-2002 03:48:35
 Re: Re: Re: John Deere B Cam Position in reply to Garland, 09-09-2002 10:44:48
Garland, if the flywheel is on wrong & the cam was timed to the LHEO mark it could be off & still have the case marks line up.
~Stick a pencil or [soft] bent wire in the L/H plug hole & turn the engine in the forward direction until the L/H piston just touches the pencil [might take 2 people], then put a mark on the flywheel at the case mark, then turn the flywheel in the other direction until the L/H piston touches the pencil again & put another mark on the flywheel at the case mark, then measure 1/2 way between those marks [that is true TDC] & should be real close to the L/H impulse mark. If incorrect [I doubt it will be off ] move the flywheel until it is correct.
~You didn't say what brand & type mag you have so we will assume a Wico unless you say different.
~Now use a tape measure & measure the circumference of the flywheel, then divide that number by 360, that will give you inches per degree, Then multiply that number by 30 [or the degrees of advance you want to run, I usually run between 25* & 30* on the U/S B], then turn the flywheel until the L/H impulse mark is lined up with the case mark & measure UP from the L/H impulse mark on the flywheel [or the mark you put on as true TDC] that amount [will probably be somewhere between 2-3.5"] then put a paint line on the flywheel there. That will be the running timing line. Now run the engine at fast idle & use a timing light to check the timing. If incorrect [I�ll bet it is] pull the mag & set the impulse stop ring [start with the impulse ring set 2-1/2 or 3 marks to the left of center & adjust from there until your painted advance mark lines up with the case mark at fast idle. Re-check the starting timing to be sure the impulse snaps at the L/H impulse to case mark lining up [the snap at L/H impulse line on flywheel to case mark is JUST FOR STARTING & isn't the running timing]. By moving that impulse stop ring you are controlling the spread between the TDC starting timing & the actual running timing.....
Garland
09-10-2002 04:17:36
 Re: Re: Re: Re: John Deere B Cam Position in reply to Clooney, 09-10-2002 03:48:35
Clooney thanks again for the info,I printed that info and will put it in my shop book. I'll let you guy's no how the B turns out might be a while but I'll post back so thanks again Garland
Mike Aylward
09-08-2002 19:49:56
G. Rainey, I suspect that your cam is probably fine but that your governor is out of time causing the timing of your tractor to be wrong. The extra heat is a tell tale sign of this. I would guess that you probably lined up the timing mark on the outside of the governor gear with the mark on the cam gear. This is a common mistake. Get the slots on your flywheel in a horizontal position and then install the governor with the magneto drive slots also in the horizontal position. The timing mark on the governor drive gear should be either in the straight up or straight down position. Then install your magneto and time it and the tractor should "wake up". Hope this helps. Mike
Garland
09-09-2002 10:30:18
 Re: Re: John Deere B Cam Position in reply to Mike Aylward, 09-08-2002 19:49:56
Mike thanks for the reply,when I put this B back together I aligned the mark on the crank gear with the mark on the cam gear(these are the only two marks on this critter)and set the mag slot to the horizontial position.I don't remember whether lefthand Exh. or lefthand impulse was up when I done this but if the flywheel was on correct it wouldn't make any difference as long as marks aligned on cam gear and crank gear would it.I'll let you know what I find. Later Gman
Paul froim MI
09-08-2002 19:39:32
Easiest way to see if your cam is timed right. Trun engineover slowly with valve cover off. Until the L.H. exhaust valve just starts to open, the L.H.Exhaust open" mark on the flywheel should be horizontal & in line with the timing mark on the crankcase. I doubt it would run at all if it was out of time one whole bolt hole on the cam gear or 120 deg. Maybe one tooth or two? If it's off at all the flywheel marks will show it, unless the flywheel was also off, but if that were the case you'd have a big vibration problem too.
Good luck, Paul
Garland
09-09-2002 10:04:46
 Re: Re: John Deere B Cam Position in reply to Paul froim MI, 09-08-2002 19:39:32
Paul thanks for the reply,The B has only two timing marks one on the crank and one on the cam gear on the inside edge these marks are lined up. I haven't had the flywheel off since I've owned the tractor,but there are punch marks on flywheel and crank so it's probably been off at some time I just assumed by it being punch marked and they were lined up it was correct,but you know what you get by (assumeing). I'll go over all aspectes of retiming this little beast,it's caused me more extra work than all my tractors put together I'm beginning to lose my patience,I was getting ready to go to a tractor show in Lanesville,Indiana but the darn thing doesn't pull the wagon to good---suffers---- so I had to load the "G" and it's heavy. Thanks again I'll let you guy know what I find it might be a while I'm sort of slow. Later Gman
