630 LPTO won't go back together
Ken
12-22-2003 17:50:54
I am replacing the cover gasket on the pto and can't get it back on. Does the drum come out or do I have to line up all the clutches and slide them into the drum? I have locked the detent on the ring and tried to align the clutches. Do I have to just keep trying this? Thanks, Ken
Clooney
12-22-2003 18:02:36
 Re: 630 LPTO won't go back together in reply to Ken, 12-22-2003 17:50:54
Ken, CAUTION that clutch drum WON'T come out without pulling the pump apart.. If you try to pull it out you can ruin the pump...
~To put that clutch pack back in, you first have to perfectly line up ALL the clutch plates with a straight edge, then lock the clutch collar into engagement to hold them there.
~Make sure there are no bent tabs on the clutch plates [those do bend easily].
~When reinstalling that clutch assembly kind or wiggle it around & lightly push it in.. If everything is lined up & set up correctly it WILL go back in...
[email protected]
mike in new mexico
12-22-2003 18:12:58
 Re: Re: 630 LPTO won't go back together in reply to Clooney , 12-22-2003 18:02:36
Ken- Clooney Is right, I just replaced the clutch pack in my 730 lp. It's kind of frustrating but you can do it ! I would add- make sure you have that fiber looking thrust washer on the end of the shaft! -mike
twopop
12-22-2003 20:24:20
 Re: Re: Re: 630 LPTO won't go back together in reply to mike in new mexico, 12-22-2003 18:12:58
mike,where in nm im in se corner
mike in new mexico
12-22-2003 20:58:25
 Re: Re: Re: Re: 630 LPTO won't go back together in reply to twopop, 12-22-2003 20:24:20
Twopop- I'm out side Portales about 10 miles. Have you had any moisture ? we are sure dry up here. dryland milo was a bust,everybody is pasturing cattle on it. Well we'll try it again next year. Merry christmas !
mike
