4 cyl. diesel problem?
Zonie
09-08-2002 10:17:31
I have a friend who has a early 70's John deere utility tractor, I don't know the model. This tractor has a 4 cyl. diesel engine that was rebuilt a few years ago. The injector pump and injectors were rebuilt at that time. It has run very well since then, until recently. Now it will start up and run a couple minutes then die. He thought it may be the Transfer pump and replaced it but it still does the same thing. He also changed fuel filters.
Now he thinks the injector pump is the problem. I feel if the injector pump was bad it wouldn't run at all.
Anyone have any ideas?
Jim B
09-08-2002 12:21:10
 Re: 4 cyl. diesel problem? in reply to Zonie, 09-08-2002 10:17:31
Zonie,if the retun line or the fitting that attaches to pump for return line is stopped up the engine will not run long.Remove fitting and see if engine will run longer.Jim
twopop
09-08-2002 12:10:13
if it is a roosa-master.or stanadyne pump,the neoprene washer inside the pump is probably coming apart and pieces of it is pluging up the return line,which will kill the engine.
