730 lift arm bushings...
mike in new mex
12-22-2003 16:40:37
I want to replace the 4 bushings in my lift arms-where the up-right pivot goes into the lift arms. Part # F-2645-R, There are 2 in each arm.
I was wondering if John Deere still has them? Has anybody replaced them recently? Thanks,
mike-NM
Clooney
12-22-2003 17:02:12
 Re: 730 lift arm bushings... in reply to mike in new mexico, 12-22-2003 16:40:37
Mike, I put a set of those in my snow plow 720D about 2 months ago. I believe I ordered AF 2862R [they could have been subbed though, I didn't pay any attention]. If I remember correctly they were fairly inexpensive.
~If yours are worn just drive a screw driver between the thinnest part of each bushing & kink the side in, then pull the bushing(s) out with a needle nose pliers.. If the bushings are still pretty thick walled use an air saw to score the bushing sides then use the screwdriver trick..
~You will need a proper fitting bushing driver to seat them back in the arms without distorting them. There was a correct size in my standard bushing driver kit ...
[email protected]
mike in new mexico- Thank
12-22-2003 18:02:49
 Re: Re: 730 lift arm bushings... in reply to Clooney , 12-22-2003 17:02:12
Thanks, I will make the trip to my local dealer and get some.- mike
Tim
12-22-2003 19:46:12
 Re: Re: Re: 730 lift arm bushings... in reply to mike in new mexico- Thank, 12-22-2003 18:02:49
Mike I just ordered some for my 720 and the part no. is F2645R and Clooney is right they are expensive.
