Engine John Deere MT
Rudy in Texas
09-07-2002 04:54:53
Try Sharp's in Fair Grove, MIssouri at 417 933-2253. They were a lot of help to me. Also be careful getting your rod bearings. It seems that there are two versions, an early style and a late style. The John Deere Parts manual only shows one, but I found there are two and I wound up with both of them, and only one fit. Hope this
Bus Driver
09-07-2002 06:40:06
 Re: Engine John Deere MT in reply to Rudy in Texas, 09-07-2002 04:54:53
The M series and the 40 series used the same engine block, but the 40 series used a crankshaft with larger connecting rod diameter. Thus the bearings and rods were different-several other parts were different between the M and 40 engines also. Perhaps the parts guy furnished a set of 40 rod bearing inserts to you.
leon
09-07-2002 05:25:50
My JD parts CD shown only one bearing, but shows that an AM225T connecting rod substitutes for an AM714T rod. Subs are supposed to be real substitutes, but on this old stuff, sometines I've fount that is not the case!
rudy in texas
09-07-2002 19:14:39
 Re: Re: Engine John Deere MT in reply to leon, 09-07-2002 05:25:50
I got my MT running this week. It took a while to get all the parts but it was worth it when it fired off and ran good.It is a whole lot of fun when that happe
Frank M.
09-07-2002 19:35:43
 Re: Re: Re: Engine John Deere MT in reply to rudy in texas, 09-07-2002 19:14:39
Yep. Sure is a good feeling. I just got my H running this week too. Whereabouts in Texas are you. I'm in Dalhart.
rudy in texas
09-07-2002 19:52:07
 Re: Re: Re: Re: Engine John Deere MT in reply to Frank M., 09-07-2002 19:35:43
about halfway between dallas and houston 8 miles south of interstate 45. a small town called Jewett
Gordon {Tx}
09-09-2002 18:01:53
 Re: Re: Re: Re: Re: Engine John Deere MT in reply to rudy in texas , 09-07-2002 19:52:07
Hey Rudy it's a small world. I'm over in Buffalo. I usually hang out on the Farmall Board. have a 45 B and a 48 M. Also a 64 model John Deere 2010, so I drop in here & ask questions too.
