H belt pulley question
CJ
09-05-2002 20:30:13
Why does the clutch drum / belt pulley on an H rotate the opposite direction of all the other John Deeres? I know it is because it is not connected directly to the crankshaft but why is it built that way? Just curious. Thanks in advance.
Clooney
09-06-2002 03:15:11
 Re: H belt pulley question in reply to CJ, 09-05-2002 20:30:13
CJ, the clutch pulley rotates backwards [& slower @ 1/2 crankshaft speed] on an "H" because it is driven off the camshaft instaed of the crankshaft. There are probably a couple of reasons that was done.
~The first is due to the fact that the "H" engine runs a little faster, the belt pulley would have to be quite small to get the correct belt speed if it was run at full crankshaft speed.
~The second is that it allows one shaft [differential], gear set, & bearings to be eliminated in the transmission, & the differential to be put on the axle shafts, instead of on it's own shaft. [my guess would be to allow a shorter, & also cheaper trans/bull gear set up].
