850 dsl
wayne
09-05-2002 19:08:10
Found a 88 850 dsl was wondering if anyone would have a idea of a good price it has no power steering the right hand brake is very hard to push down an it will not come back up.It has 867 hrs.Just hoping someone here would help me out. Thanks for any help
Bear
09-09-2002 01:57:06
 Re: 850 dsl in reply to wayne, 09-05-2002 19:08:10
These are good tractors that are built by Yanmar.
I would venture a guess that a 4wd with low hours and in good shape would bring $7000 up in my country. A 2wd is less desirable here, probably $4000 up. DC
JDGnut
09-07-2002 09:14:01
I'm not good on the prices.. On the breaks that is normal for a tractor that doesn't get used much, and is not too hard to fix.. Normally it just needs to be taken apart and cleaned.. The shaft that goes through the housing is what usually sticks, and the brakes will be Ok.. These little tractors will take a beating, and you can work them hard.. but don't over heat them, they will crack the head. (about the only way to over heat it is get the radiator pluggd, also check the inside of the radiator.) They make great little tractors.. We have a '88 750..
JDGnut
