JD Plow with Slotted Moldboards
Dennis K.
09-04-2002 11:44:33
My brother just gave me a John Deere two bottom plow that has the slotted moldboards. We can see the words "John Deere" embossed into the frame. I got to spend a little more time and see if I can find any other markings (model number, part numbers, ...). Does anyone know where I can find some information on this plow (websites, books, JD catalogs, ...)? Thanks,
dean Van Peursem
09-10-2002 15:14:03
 Re: JD Plow with Slotted Moldboards in reply to Dennis K., 09-04-2002 11:44:33
I can help you identify the plow if you can find the two beam numbers.
Bob Collins
09-05-2002 09:20:05
Dennis, I think this is as good a spot to find info as any, let us know some numbers and we can likely help. Look after the words JOHN DEERE on top of the beams for a number. Bob
Will P
09-04-2002 20:54:20
Here is a web site that has alot of plow beam numbers.
Will P
Dean Van Peursem
09-09-2002 17:47:17
 Re: Re: JD Plow with Slotted Moldboards in reply to Will P, 09-04-2002 20:54:20
I am the one who published that list of plow beam numbers on ATIS. It has been updated considerably since then and Green Magazine has run a series on plows the last few months providing beam numbers for many different plows. If you find the engraved/stamped numbers in the beams just before they turn down to the plow bottoms I can probably help you identify which plow you have.
Paul from MI
09-04-2002 20:13:22
Don't know much about what plow you might have. You can usually find some info from the numbers on the beams. Usually slotted bottoms were used where the soil was heavy clay or "jackwax" which was difficult to scour the mold boards. Slotted mold boards made more pressure in one place and helped the bottom scour. Pretty rare in our part of the midwest(Ohio-Michigan).
Hope this helps,
Paul
Jhill
09-05-2002 07:18:58
 Re: Re: JD Plow with Slotted Moldboards in reply to Paul from MI, 09-04-2002 20:13:22
Actually they used to be common in areas with muck soils in Michigan. There used to be alot of them in the Sandusky area where they have really sticky soils.
barry eliason
09-05-2002 20:04:17
 Re: Re: Re: JD Plow with Slotted Moldboards in reply to Jhill, 09-05-2002 07:18:58
hi, i'm from sandusky! never saw one of those. who am i talking to?
