Crank end play
david
09-03-2002 18:37:53
How do you adjust the crank shaft end play on a 1936 B John deere. Does it have something to do with moving the fly-wheel in/out?
Paul from MI
09-03-2002 19:12:32
 Re: crank end play in reply to david, 09-03-2002 18:37:53
Adjust the end play loosening the flywheel, adjusting to .005-.010" play. Easiest way is to engage clutch, put hydraulic jack between end of crankshaft and right rear wheel & jack crankshaft to the right. then slide flywhell all the way on the crankshaft, paying attention to the marks on the crankshaft & the flywheel. Tighten flywheel & you should be about .005 to .010" end play. LOL
paul
