2040 temp gauge
blake simpson
09-03-2002 17:54:01
I have a 1979 2040 that when I turn the key to on the temp gauge and fuel gauge peg out. I don't know if it is the gauge or the sensors. I ohmed out the temp sensor while the engine was warm and the resistance decreased as the engine cooled down. Someone has really messed up the wiring and there is only two wires connected to the back of the gauge but there is three or four connections on the gauge. Any help would be appreciated
Craig-MN
09-03-2002 21:00:43
 Re: 2040 temp gauge in reply to blake simpson, 09-03-2002 17:54:01
It's been a while since I've worked on those gauges. They do require a good ground connection. Since you say BOTH gauges peg out, perhaps he panel the gauges are mounted in has lost its ground to rust or corrosion? Make sure both gauges have good connection to the panel too.
