Another 45 loader question...
F-I-T
09-03-2002 14:25:06
I need to replace the top pivot points on this loader, and of course they are NLA. They consist of an open ended cylinder (like a piece of pipe), 1 1/8"od , 3/4" id, and about 3 1/4" L. I figured I'd have to go find a shop with a lathe to turn two out for me, but then it hit me....
Could I use a couple of worn out wrist pins ? They'd be the toughest pivot material you could find.
Anyone know which 2 cylinder wrist pins would be 1 1/8" od (the dimension I want to hold) and no smaller than 3/4" id (a little larger would be fine to clear the through bolt), and 3" minimum in length ? I don't have any specs handy or I'd look it up myself. I'm guessing an "A" or "B". Or any other engine that I might find some junkers from. Maybe a 3010/20,4010/20 ? I'd use the ones from the 70D, but they're 2.355".
Open to any suggestions.
Thanks for helping with my crazy idea.
Frank-in-Tallahassee
70D // 855
NATHANIEL WATTS
09-04-2002 09:11:29
 Re: Another 45 loader question... in reply to F-I-T, 09-03-2002 14:25:06
We have had good luck using old cylinder rods as they are chrome plated. They seem to last a long time in a track loader.
