JD 60 mis at idle
JD JACK
09-02-2002 18:49:04
My neighbor has a 60 that is missing at idle, if brought off idle, miss is gone. He has replaced cap, rotor, plugs, wires, coil, condensor, pionts, and still misses. I think he said that the carb, has been gone through, not sure though.
any suggestions?
DON
09-03-2002 17:16:33
 Re: JD 60 mis at idle in reply to JD JACK, 09-02-2002 18:49:04
I had this happen to me once, check the throttle plates to be sure they are both closed together . one could be cocked a little,back out the idle screw and loosen both plates then tighten them with the plates closed.
KEN C.
09-02-2002 19:37:05
Could be one of the idle air adjustments is plugged. Check for air intake leak where manifold bolts to head and carb to manifold, could be sucking air, will miss at idle.
