Flooding B update....
HMan
09-02-2002 16:54:32
Still won't run. I checked the adjustment screws,fine. The float has no hole,and "floats" well. The needle was clean and not stuck. The float was set higher than the IT manual setting. So I lowered it and is now set at 1/2" from top of the bowl to top of the float when needle is closed. Still alot of fuel in the cylinders. I checked the timing and tried differant plugs and she won't even hit now. Has a good spark but not really a blue one. This is frustrating. This is an easy starting great running tractor,now nothing. HMan
Link Shadley
08-13-2005 20:26:25
 Re: Flooding B update.... in reply to HMan, 09-02-2002 16:54:32
Have any success? We have a 1939 A/C B that floods very easy - there is a fine line between getting enough gas into the cylinder or too much! If cold, I'll put on full choke for one crank, then full open for several cranks, throttle about 3 notches up. That works fairly well.
If warm, it will usually start with no throttle and no choke. If I have to give it a bit of throttle, it is easy to flood and then I'm cranking for 10 minutes to dry it out.
Once running, it purrs and has never stalled.
Are other A/C's this way? Any thoughts on carburation adjustments I can make?
We just ran her in the Dufur Threshing Bee Parade (Oregon) and had a ball!
Clooney
09-02-2002 18:38:05
HMan, pull the plugs out & either crank it or pull it in gear to clear the cylinders of old gasoline. Then leave the plugs out for a while to allow the cylinders to vent. ~If it won't start after that you might have washed the cylinder walls of oil lowering the compression enough that it floods easily when trying to start. Put about 3 oz of oil [preferably 2-cycle oil] in each cylinder then turn it over by hand to lube the cylinder walls.
~If you have a good spark it should be blue, if it is yellow it might not be enough to fire under compression. Take an old spark plug & open the gap to 1/4" then see if both L & R sides will fire across that gap multiple times, if not you have probably found your problem, if it can't produce a decent spark it will flood very easily.....
