JD LX 178
Curt
09-02-2002 11:18:49
I have a problem with my JD LX 178 Lawn tractor! When I first start it runs great, after 15-20 minutes it will just die. I can start it back up and it will run for 5-10 seconds and die again. If I let it sit for a couple of hours it runs great again for 15-20 minutes. I replaced the fuel filter and this did no good. My next thought is the fuel pump does anyone have any ideas?
Thanks Curt
Ruby
06-23-2004 16:58:45
 Re: JD LX 178 in reply to Curt, 09-02-2002 11:18:49
I have this trouble with my John Deere Lawn Tractpor. Does anyone know of a fix?
It actually ran for 3.5 - 4 hours after a tune up and then the next day only about 20 minutes
Bama Binder
09-03-2002 11:37:18
Dunno...Mine is somewhat similar in that I have a surging problem that gets worse the longer it has been used. I haven't dug into it to try to find the problem, but a new set of plugs helped a lot. I also notice it more when the fuel level is low on the tractor.
At least give some thought to these things, but it sound more like the carb / fuel system.
