John Deere A heads interchangeability
Pete Bordovsky
09-01-2002 23:31:58
I'm new to this discussion board and would greatly appreciate any help with a problem I've created. I'm working on a 47 A with head problems and haven't had very good luck. The original head on it was a # A2325R and I finally found a good head with a # A4226R. I installed the new head and couldn't get any clearance on the valves. I measured the head (A4226R)thickness and it was approximately 5 1/4 inches tall. I measured the old head (A2325R)and it was about 5 1/2 inches tall. I obviously have to do something different but what is it? Can I use this new head with different tappets or pushrods or what? I would appreciate any helpful advice that someone has. Thank-you.
lynn
09-03-2002 17:51:40
 Re: John Deere A heads interchangeability in reply to Pete Bordovsky, 09-01-2002 23:31:58
Pete..shorten the push rods 1/4 of an inch and it will work ok..will raise the compression some but if using old kerosene pistons will not be problem..if gas pistons may take compression to 7.5 to 1..lynn
Pappy
09-02-2002 23:57:55
The A2325R head fits up to serial number 583999.
The A4226R or A3367R fits from 584000 on up.
