How do you tell if a tractor is all fuel or not
david stiles
09-01-2002 15:59:22
hi i was wanting to know if my tractor is a all fuel or not it is a 630 jd serial no 6307259 it has the back hole in the hood by the steering pedestal missing small tank it also has the one piece intake and exhaust manifold. is there a way to tell for shore on this?
thank you very much
david stiles
Gene Davis
09-01-2002 21:01:07
 Re: how do you tell if a tractor is all fuel or not in reply to david stiles, 09-01-2002 15:59:22
Worked for John Deere dealership in 50's & 60's, and you could listen to a 2 cylinder engine at work and tell the difference, the fuel burner always sounded like it was slobbering and the gas burner always had a clear crisp sound to the exhaust tone. You didn't even have to see the tractor, you could listen to the sound of it and speed of the engine and tell if it was gas, or fuel, dubuque, or waterloo. Can't distingush that with the newer engines, that can run at variable speeds. Gene
Wayne in Tn.
09-01-2002 18:46:47
David, the Dubuque tractors that were (all fuel) had a petcock on the left side of the oilpan, to drain off excess fuel in the crankcase. Don't know if the Waterloo tractors had them or not.
CLW
09-01-2002 18:42:27
37G is correct. Your tractor was shipped 3-12-59 to the New Orleans branch then to Athens, AL. It is an all-fuel.
CLW
37G
09-01-2002 17:12:59
According to march-april issue of two-cylinder you tractor is listed as a all fuel originally shipped to athens AL. this info could but is probally not incorrect but you can right a letter to two cylinder and ask
david stiles
09-01-2002 20:21:26
 Re: Re: how do you tell if a tractor is all fuel or not in reply to 37G, 09-01-2002 17:12:59
thank you for the information on this tractor so it is a all fuel is it true that they only produce around a 186 of these tractors should this tractor go back as a original then.
thank you
david stiles
