JD G
Pete
08-31-2002 04:44:06
I looked at a G today when it first started up, a little bit of radiator fluid came out of the Muffler it quit right away, but the tractor had a little miss and pop for the first 10 min. then it smoothed out and was fine. I was thinking head gasket or cracked head.There were no air bubbles in radiator when it was running,and there is no water in the oil. How much of a fix$$ is this. Also it has a JD 45 trip bucket loader on it what is this thing worth .Thanks in Advance
G-MAN
08-31-2002 09:53:58
 Re: JD G in reply to Pete, 08-31-2002 04:44:06
Although you always want to assume the worst when going into these situations, especially as a seller, it could be as simple as a head gasket. My 60 does the same thing. Coolant seeps into one of the cylinders if it sits for a long time, and then it misses on that hole until it cleans itself out - then it runs fine. As long as their is antifreeze in the cooling system, it probably didn't do a lot of damage to the cylinder walls, but there might be some light corrosion. Either way, it sound like you're going to be pulling the head at least, then you can check into things further.
