JD 4020 clutch
del
08-30-2002 17:58:45
My son put a new clutch plate, pilot bearing, throwout bearing,and pressure plate in his 4020 last week and the PTO is engaged all the time. The PTO lever is in the disengaged position and the PTO turns. I thought it must stuck but he told me he bush hogged with it and it didn't come loose. He removed the bottom plate and said there is free play in the PTO clutch fingers. He's working on another tractor right now and hasn't had time to split the 4020 again. I told him I'd ask around for advice before he splits it again. Thanks for your help!
twopop
08-30-2002 20:19:01
 Re: JD 4020 clutch in reply to del, 08-30-2002 17:58:45
if the two halves were pulled together with the clutch housing bolts,then the pto clutch disc is probably bent and is grabbing the trans disc.this happened to me about the second time i split a 4020.since there are two shafts and two discs,it is very important that all are in line before tightening any bolts.
