60 clutch drive question
Jack
08-30-2002 14:20:06
Is there any wat to stop the clutch drive gear from creeping in on a 60?My friend had it pressed on again and he thinks it has moved again.
Clooney
08-30-2002 15:02:02
 Re: 60 clutch drive question in reply to Jack, 08-30-2002 14:20:06
Jack, I've had a few tractors that the drive gear has migrated on & usually just press it back on & it stays. I don't know if Loc-Tite will do you any good as that gear is such a tight press fit that it will push the Lock-Tite out of the joint as it is pressed on. I guess if it were mine & the gear moved again I would tac it 4-5 places with a welder [small spots], or maybe even grind about 5 little chamfers in outboard end of the gear bore [while the gear is still out] then stake the pulley into those chamfers after the gear is pressed back on...
