G john deere
cwj
08-30-2002 05:40:28
does anyone know what the horse power is on a G
JD790
08-30-2002 11:00:48
 Re: G john deere in reply to cwj, 08-30-2002 05:40:28
Check your EMail for a JD HP Chart.
Jack
08-30-2002 10:09:18
Truthfully there is lots of variables in the actual hp,but the Nebraska tests have the G at 38 hp on the pto.A G with a gas manifold and the factory cast all fuel pistons(say about 60 to 65 psi per cylinder)will pull about 44 hp on a dyno.High compression pistons will get you around 53 to 55 hp.Later,Jack.
Scott Penrose
08-30-2002 07:25:17
The G had 34.5 at the drawbar, 38.1 at the belt.
2 cylinder
08-31-2002 20:03:07
 Re: Re: G john deere in reply to Scott Penrose, 08-30-2002 07:25:17
A JD-G BORED .90 OVER WITH HIGH COMPRESSION ALUMINUM PISTONS AND A FLAT HEAD WILL NET YOU 70hp.
