Hey seamo
howard
08-29-2002 10:13:31
the tank and outlet are clean gas bowl good new screen as for the rest left side 108lbs right 105 lbs 12 lbs leak down test on head all reading at 170to 180 degrees f hole ingnition new eltronic with 45k coil all new wirering harness big battery dry air filter no smoke and will pull to last pop if you let it but if the gas line is the wrong size could i get moore out of it on .The dyno it pulls down never skips a beat rpm is set at 950 with digital tack i want to keep it 99% stock but woul like all i could get out of it with what i have to work with or am I at that point now
thanks seamo
09-03-2002 04:05:19
 Re: hey seamo in reply to howard, 08-29-2002 10:13:31
seamo thanks for the advice the vent was taken out and cleaned it before it was glass beaded it was all apart includeing all plugs I did fine it has only qourter inch line on it instead of the 5-16 line it should have I will see what happens on the 14 with a new 5-16 line and fitings thanks again howard
Seamo
08-29-2002 12:12:26
Howard, The problem in the carb could be in the needle and seat area.When you cleaned the carb did you pull the nozzle?? You know in 50yrs a lot of people could have been into that carb. I have found some with the wrong nozzle.One of the most over looked thing on 71 series carb is the bowl vent. You have to remove them to get it clean. It is only available from Deere.If it is plugged you will have no vaccum in the fuel bowl therefore the fuel wont run into the bowl fast enough to get enough flow for the load side of carb.I highly recommend you go buy service manual #SM2024 from Deere if you are going to fix these carbs yourself. The other carbs will have the same problem but this 71 series they put the double brass baffle in the hole to keep it from sucking fuel in the bowl vent on rough ground.Some after market needle and seat the hole where the fuel flows is too small if you are pulling dead load throttle plate wide open it wont flow enough to keep the bowl full. The hole where the load needle seats has too be clean. Check close it could have a nice layer of rust in the hole. Plain old carb cleaner won't clean these carbs.EARL
howard
08-30-2002 04:03:19
 Re: Re: hey seamo in reply to Seamo, 08-29-2002 12:12:26
seamo thanks for the in put .the carb has a new nozzle in it .it was tanked then cleaned then glass beaded and cleaned again when done it looked clean but will check it again i have checked the cap to I think i will replace the gas line it seames clean but maybe after 50 years it is crusted up in side and and restricted and see what i get of the tractor again at the next day of fun with aload on it thanks again howard ps all the parts for this carb came from roberts so i whould hope they are corect
SEAMO
08-30-2002 10:01:56
 Re: Re: Re: hey seamo in reply to howard, 08-30-2002 04:03:19
HOWARD!!!! Are you going to promise me to look at that BOWL VENT.I know it's full if you didn't remove it when you glass beaded it. PUTT!!PUTT!! IT will run better with the baffles out and the holes cleaned than with them plugged. But they should be put back NEW. Let us know if you had fun or wished you had fixed it.
