Carb flow
hey semo
08-29-2002 06:55:58
you were talking abount carb flow in dlxt 71 and the big nut 51 is there a diference in the line size going to the carberator and if so what size line should be on a 1948 A with 71 carb . the reason I ask is that when I dyno my a last weak full load i did not get any beater responce from up 12 click from the load screw { carb redone all gasgets neadle seat new nozzile throtal shaft all hand reemed bushings new plugs and the and the drill bits cleaning } the A runs real nice but dawgs out on tail end of the pull I have good gas flow but am thinking wrong gas line size for full load might not be right .It dynoed a fat 30 hp ALL STOCK not shore over bore has been done is thier moor hp t be found or am i looking for a dream in a all stock machine thanks for any thoughts howard
Jim
08-29-2002 09:12:25
 Re: carb flow in reply to hey semo, 08-29-2002 06:55:58
You may alos want to check fuel flow from tank into the fuel bowl,dirt and rust does get into the fuel bowl inlet,another area to check is the srean at the fuel inlet of the carb,if the carb is gone through should be like new-
mike
08-29-2002 08:03:35
use a 5/16" fuel line for the A. Are you expecting too much from your A? to not dog out they will pull down to the last pop if the wheels can spin slightly.
Seamo
08-29-2002 08:00:56
I could fill a page about air flow and fuel flow. You need to tell me more how your tractor acts on the dyno.Is this tractor stock? How much compression does it have?? Can you make it smoke with no load by opening the load needle??? Does it start out rich then clears up then sputs and dies??Stock HP. is 35-38 you are down 20%
