JD 400 Backhoe in the UK
Hebridian
08-29-2002 04:47:51
I have a JD400 Backhoe, I beleibve it was manufactured in Germany and was first registered in the UK in 1975.
When I purchased the unit , it had a small leak from the shaft of the pump. I have had the pump re-built and when it was fitted I was able to raise the front bucket fine3, but as soon as I tried to move the rear arm, the oil seal on the pump shaft blew (totally). I have since had the pump rebuilt again and exactly the same thing happened. We are trying to get some manuals and diagrams on the hydraulic system but at present we are working blind. Anyone have any ideas what is wrong and where ? John Deere are being as hepful as possible but are quoting 6 weeks for the manuals.
Thanks in advance
Hebridian
Kent, England
Jim in UK
09-02-2002 06:53:48
 Re: JD 400 Backhoe in the UK in reply to Hebridian, 08-29-2002 04:47:51
Sorry, but I am not very familiar with the JD 400.
But I have worked on a few CASE, IH, and other John Deere's. If it's blowing that seal out like you say, you most likely have another problem with it. You may want to check the relief valve, and possibly the plumbing on the system. It sounds like you have another problem and it may be elsewhere in the system.
