JD Lawn Mower
William (VA)
08-28-2002 07:01:19
This is not a 2 cylinder problem, but I have a STX 38 JD mower with a Kohler 12.5 HP engine that is acting strange. Sometimes when you turn the key, the starter clicks. If you repeat this process several times, it will kick in and start. The solenoid went bad this spring and I thought that might solve the problem, but it did not. If I remove the starter from the mower and ground the corner of the starter to the block, it engages every time I turn the key. I thought it might be a ground problem and I checked all the connections and that didn't help. Anyone had a similar problem? Any suggestions? Thanks
DN
08-28-2002 14:15:53
 Re: JD Lawn Mower in reply to William (VA), 08-28-2002 07:01:19
check the engine mounting bolts there known to come loose and check the ground wire. on a yellow decked mower check the tranny nuetral switch and on a black decked mower check the clutch pedal switch
Sam Vastano
08-28-2002 07:30:14
Check the safety switch that mounts to the bottom side of the seat. Mine acted up before. I just unplugged it. I know not really safe but neither is a 46 B with a 6ft finish mower. No ROPS etc.
Sam
