1955 JOHN DEERE 50 OVERHEATING
MIKE LOKAI
12-21-2003 17:17:52
HISTORY: RECENT OVERHAUL MOTOR (NEW PISTONS/RINGS) NEW RADIATOR CORE AND THERMOSTAT
PROBLEM: TEMP GAUGE READS 168-172 AT IDLE THRU FULL THROTTLE FOR 20 MINUTES. EXTERNAL TEMP --BLOCK-200-F --HEAD-400-F AFTER 10MINUTES PULLING FIELD PASTURE DRAG--HEAD BEGINS TO SMOKE AND WITHIN 3-4 MINUTES ENGINE LUGS DOWN AND STALLS AFTER 2-3 MINUTES ENGINE WILL RESTART AND GO THROUGH THE SAME PROCESS.
NO EVIDENCE OF BLACK OR BLUE SMOKE RADIATOR/OIL LEVELS--NORMAL RADIATOR INTAKE--WARM TO TOUCH RADIATOR OUTFLOW--VERY WARM BUT NOT HOT NEED HELP THIS IS WIFES PULLING TRACTOR!
MIKE LOKAI
12-23-2003 16:33:00
 Re: 1955 JOHN DEERE 50 OVERHEATING in reply to MIKE LOKAI, 12-21-2003 17:17:52
THANKS TO MY GOOD FRIEND CHARLES NIX AND BI=LO
MACHINE SHOP. HE SOLVED THE OVER HEATING PROBLEM
AFTER A GOOD OLD FASHION CARB. CLEANING, THE WIFE'S PULLING TRACTOR IS BACK TO NORMAL AND I'M OUT OF THE HOT SEAT!!!!! ! BY THE WAY CHARLES CAN
TAKE CARE OF ALL YOUR BLOCK AND HEAD NEEDS AT
[email protected]
Mike M
12-22-2003 12:00:51
What type of pistons and do you know how much skirt clearance you have ? I knew a guy once built a puller A it ran good but would lock up when worked. Turned out the big nut carb. that was rebuilt was not done right and the extra fuel inlet hole was plugged makeing it run lean. Your pistons may be too tight ?
zane
12-21-2003 18:02:36
Sounds like something's obstructing coolant flow. Remove the thermostat and try again. That done, I'd question whether the right head gasket is installed.
