420 W oil pressure
Russ
08-27-2002 12:31:22
My 420 W operates in the green section of the pressure guage at full throttle, but drops to half way into the white when idling. What is normal. Should I check with calibrated pressured guage to ensure good oil pressure ? what should the oil pessure read, both at idle and full throttle. Should I be concerned ? Should I adjust the oil pump pressure ? I'm using 10W30 oil. Thanks for all your help.
Russ
08-28-2002 08:22:31
 Re: 420 W oil pressure in reply to Russ, 08-27-2002 12:31:22
Henry J
08-27-2002 18:42:37
Russ
My worn out 420 runs the same oil pressure. Right now I am running a dukes mixture of 2 qts of 10W40 and 2 qts of rotella. One thing I don't do on mine is let it set around idling at low RPM. That has a tendancy to foul the rear plug and I personally don't like to see the pressure that low on the oil guage. I prefer to let her pop at 1000. It seems happy there :). Have fun and keep the correct police from staring at your guage.
Clooney
08-27-2002 16:10:15
Russ, the oil pressure is checked HOT at wide open throttle [should be 30 psi + or - 5 psi].
~Yours doesn't sound too bad for a used & worn engine using 10 w-30 oil.
~Adjusting the pressure won't do you any good if it is capable of running in the green at WOT & drops off a idle [it's already set high enough to run in the green so if it is less at lower RPM's the pump can't keep up].
~Personally I don't like 10W-30 oil in an older M-430, & much prefer a straight weight 30 weight. I will run multi-weight in the winter if I'm going to use the tractor in extreme cold conditions though.....
