420W brakes ?
Russ
08-27-2002 11:55:17
The brakes on my 420W are just not working as they should. I have completely removed them, several times, and made sure every thing was cleaned, loosened, no oil present, adjusted for max engagement and resurfaced the pads by hand. The pad do not look too worn as the radial grooves are still very evident...say 3/16 deep. The ball and grooves also visually look ok.. Question: What should the width of the disk/pad measure when new. Also, what should the total width of the actuating brake disk assembly measure, minus the pads. Any help in trouble shooting the root cause would be greatly appreciated.
Henry J
08-28-2002 11:36:28
 Re: 420W brakes ? in reply to Russ, 08-27-2002 11:55:17
Russ
As I recall, the adjustment on those are 1 to 1 1/8 inch of free travel. It appears that you have taken them apart more than once. Did you have to clean them each time? I am just guessing. If so have you checked the drain hole in the bottom of the brake well. It is about 1/8 inch in diameter and if it has not been cleaned in 20 or 30 years like mine it will take a drill bit of the right size to clean it out. Just a hunch and something to check on. My tired ole 420 W has mix and match brake disks. The brakes have worked fine since I have cleaned up everything and cleaned out that drain hole. Just a thought.
Thanks from Russ...will do (nt)
08-29-2002 09:49:58
 Re: Re: 420W brakes ? in reply to Henry J, 08-28-2002 11:36:28
NT
