Block Heater
Jake mb.
12-21-2003 16:10:08
I use a J.D. AR handstart to clear my yard in the winter.I was wondering what you have found to be the best way to get some heat into it on those really cold mornings up here in canada.I have tried a circulating heater but it seems to take a long time to get enough heat to start it at -15.
Thanks to everyone for all the helpfull advice all year long and a MERRY CHRISTMAS to everyone.
Bob
12-21-2003 18:48:42
 Re: Block Heater in reply to Jake mb., 12-21-2003 16:10:08
What pipe thread size is the drain plug in the head, 1/2" or 3/4" pipe thread?
Temro probably makes screw in heaters for both sizes, and their headquarters is in Winnipeg.
Check out application listings at:
http://www.zerostart.com/pub_AppGuides.asp
AR Roger
12-21-2003 17:12:26
Jake, I've got a styled AR & have found the block heater from a 2000 V6 ford Escape is the same thread as the big coolant drain plug in the bottom of the cylinder head. It's only 400 watts & I plug it in the night before & the old girl will start at -30c. (not a hand crank,tho)I also use 5w-30 oil in the northern Ontario winters here. John Deere may have a stronger one if you check with them!! Princess Auto also has magnetic heaters that will stick to the bottom of the crankcase (or anything iron eg.trans) that make lotsa heat. Check them out!!
