4-rib tires for 1010
M.Beam
08-27-2002 09:39:35
I'm having a hard time finding some 4rib tires that will fit my 1010. I will be cutting grass with this tractor and needed something a little better than implement or turf tires.
Any suggestions would be appreciated
Clooney
08-27-2002 17:51:48
 Re: 4-rib tires for 1010 in reply to M.Beam, 08-27-2002 09:39:35
M.Beam, I don't know what you mean by "better" than implement tires for a grass cutting tractor. ~They have nice round edges, hold up good, can be had in 4 or 6 ply [4 would probably be better for lawn type mowing as they are a little softer & will do less damage]. Maybe 6 ply for thorny or rocky use, or field brush-hogging. Maybe a little weak in the sidewall area but unless you are going to rub rocks or stumps they should work fine...
G Taylor, plan B
08-27-2002 21:34:20
 Re: Re: 4-rib tires for 1010 in reply to Clooney, 08-27-2002 17:51:48
Firestone in the 5:00-15 makes a H-1 5.9-15 four ply, implement and an I-1 5:00-15 Implement. 6:00-16 come in F-2 six ply and H-1 6:50-16 six ply.
Of course used aircraft tires can be cheap have ply ratings in the teens & 20's.
G Taylor
08-27-2002 21:30:47
