Draw bar length ?
Morgan
08-27-2002 08:00:52
Does anybody know what the length of the swinging
draw bar for a 49 JD A ? I need one for my tractor. Thanks, morgan
Terry H
08-27-2002 09:48:38
 Re: draw bar length ? in reply to Morgan, 08-27-2002 08:00:52
Jim,
I keep hearing that it doesn't matter ;)!
Seriously.....46 inches sounds about right. I'll measure the one on my '50 A when I get home and post results.
Terry H
Jim from Stonepile
08-27-2002 09:29:41
Mine measures 46 inches.
your go guy!
08-28-2002 13:12:58
 Re: Re: draw bar length ? in reply to Jim from Stonepile, 08-27-2002 09:29:41
Bet that tears um up!
Morgan
08-27-2002 19:50:57
Thanks, I only bought this tractor about 6 weeks ago.my friend inherited it and he didn't want it so I made him an offer and he took it. The draw bar was missing a piece so I added what I thought was about right and I was wrong. Too short! today I made it 46" long and that was just right!! I have a John Deere GYRAMOR 207(I think?) any way I needed to mow the weeds ,now It works great!!!
thanks again!! morgan
Mike Aylward
08-28-2002 05:25:45
 Re: Re: Re: draw bar length ? in reply to Morgan, 08-27-2002 19:50:57
Morgan, to be sure your drawbar is the right length and adjusted properly for your pto application the drawbar hole should be 14 inches from the end of the pto shaft (or 16 inches on a 1000 rpm shaft, which of course you don't have). This will assure smooth power delivery on your cutter (or any other pto job you do). Hope this helps. Mike
Morgan
08-29-2002 15:41:23
 Re: Re: Re: Re: draw bar length ? in reply to Mike Aylward, 08-28-2002 05:25:45
Thanks Mike! I measured like you said and it was 15 in. I made the draw bar 47 in. works real good-thanks. morgan
