How well do the replacement taperlock flywheels work???
Bob
08-27-2002 05:56:13
I have a JD 70 Gas with the typical flywheel problem. The Spline is worn, and a stock flywheel will not do the job (I've tried two already).
I wonder if anyone knows how the taperlocks work and if there are any tricks to them.
Thanks in advance.
Bob
abe
08-29-2002 10:10:00
 Re: How well do the replacement taperlock flywheels work??? in reply to Bob, 08-27-2002 05:56:13
do they make taper lock clutch side\for worn
crank splines on that side
38 jd a thanks abe
TB SCOTT
08-28-2002 08:50:30
I put one on a 720 diesel in 1985 and its still going strong!! :-)
Bob-Wyo
08-27-2002 12:59:39
Bob I have been checking out the same thing for a 730D, the trick is not to put it on and forget it. We have 2 different shapes of splines and the need to conform to each other, so the need to run/tighten, run tighten and so on till they conform to each other. The amount of times to retighten all depends on how bad the crank splines are. I will leave the flywheel cover off so it will be easy to retighten at any time.
You can call Rusty Acres to confrim this if you like, like he said that is what they were made for, bad crank splines.
Hope this helps.
Bob-Wyo
ChuckW
08-27-2002 10:02:04
I have a 730 diesal for sale on ebay and it has a taper lock and has been in service for many years. It's a proven item.. Expensive $800.
