JD60 Duplex carb choke
Leon R
08-25-2002 20:16:11
I am having one heck of a time trying to assemble the small spring and choke lever to the carb so that it works. I have the carb breakdown pics but it is not clear. It even appears to me that as the choke lever is pulled forward towards the rear of the tractor that that action actually opens the butterfly valves rather than closes them. Anybody have any idea what I am doing wrong?
Walt in Jaxn, Tn.
08-25-2002 21:50:01
 Re: JD60 Duplex carb choke in reply to Leon R, 08-25-2002 20:16:11
had the same trouble with mine, don't give up common sense will finally show you how it works. the reason it's there is to automatically open the choke enough to not flood the engine after the engine starts untill you manually open it so don't get frustrated and try to bypass it. remember with the lever at 2 o'clock the choke will be closed and you should be able to push it open inside with your finger when it is correct with the spring trying to keep it closed.
