JD 2640 hard start when cold
dave
12-21-2003 13:24:00
Just got a 2640 and don't know much about them. Does this tractor have any glow plugs or any kind of heating device to assist when starting cold? Starts great when it is warm.
Any ideas?
Catskill Pete
12-22-2003 11:10:17
 Re: JD 2640 hard start when cold in reply to dave, 12-21-2003 13:24:00
Welcome to the club, most of the 2640's are a bear to cold start. If your looking for a "cure" let the rest of us know if you find it. That being said the best way to deal with it is a block heater. JD dealer can supply what you need. The either I would use only when you have to. 90% of the time I know I,m going to need the tractor and can plug it in an hour or so before i'll use it. The either is for the other 10%. Jd has an either injector kit that was sold as an option. Your tractor may already have it, on the dash look for a fixture that sticks out and looks like a 90 degree elbow with a cap that screws off the bottom. If you don,t have one, I would highly recommend you get one. {JD dealer} The either injector restricts the spray enough to make it difficult to "overdose" the engine, not impossible but difficult.
buickanddeere
12-21-2003 22:14:02
My Uncles 1640 had a similar problem. They use two 12V batteries in parallel. One battery maybe a dud or a dirty conection/cable problem on yours. His started much better when both batteries were cranking the engine. Install a block heater and synthetic 15-40 or 10W-30 engine oil. Was it not equiped with the intake manifold heater?
david val
12-22-2003 00:43:12
 Re: Re: JD 2640 hard start when cold in reply to buickanddeere, 12-21-2003 22:14:02
acc. to the pc, 2640's had ether cold starting device. i dom't know weather it was standard or an option. there is no kit in the pc, just individual parts. look for the ether can receptacle under the dash. european models had "thermostart" system that used a glow plug in the intake manifold with fuel from a small reservuir that flows through the glow plug when it gets hot and actually creates a fire in the manifold.
david
Dan
12-21-2003 13:40:54
No glow plugs, yu can use a block heatre to warm up when cold. You can also use either, sparingly, spray into intake when engine turning. Block heaters work good and your engine isn't totally cold when you start it.
