JDJACK
08-25-2002 17:41:35
I had just rebuilt the transmission in my 1948 B. put all new bearing in, different transmission drive gear, new counter shaft idler gear, and counter shaft, detent springs( old gears had some broken teeth). Well it sound alot better now. BUT I hooked it up to the disc and started discing, going good for awhile, just as I though that I had fixed the problem thud! The tractor quit moving, still in 3rd gear slot, moved out of 3rd and up to 5th engaged clutch, nothing, tried 6th nothing, tried 3rd again, nothing, tried to move level to right side of quadrient, won't move down from thrid gear outer slot to bottom of channel. Hit shifter down with hand and went. put into 2nd gear, engaged clutch, and moved, shift back to 3rd engaged clutch and moves. Kept going, and same thing happened again. Said a few words. Unhooked disc and went home. I had installed all new detent spring and adjusted them good (or I think so). I am having a hard time figuring this out. Is this a problem with the overdrive yoke? The shafts worn? I don't have a clue. If any can help please post back. Thanks JD JACK.
