Clooney, I forgot something
JD60
08-25-2002 15:27:43
Clooney, I put my flywheel back on with the JBweld, it hardened, now I can't turn it by hand, the starter turns it. I think I have almost zero end play...now what will it be alright???
Thanks!!!
Whoops!! JD60
Clooney
08-25-2002 16:14:46
 Re: Clooney, I forgot something in reply to JD60, 08-25-2002 15:27:43
JD60, you need some end play or risk thrust washer damage. By "almost no end play" are you saying you have some? If so run it for about 1 minute & try to turn it by hand. Then re-check the end play [you will need at least .004"] If you have none then you will have to loosen the flywheel bolts & pull the flywheel then remove all the old JB weld & start over. You will probably need to make a puller if the JB is holding at all but it should come loose after you loosen or remove the flywheel bolts..
JD60
08-26-2002 14:02:35
 Re: Re: Clooney, I forgot something in reply to Clooney, 08-25-2002 16:14:46
Thanks!!!
I ran it, and I can turn it by hand just as before.
I'll check for the actual end play.
Otherwise it runs very very quite.....NO MORE NOISE!!!!!
Thanks!!! Clooney!!!!
