My 1st 720//Clutch is stuck(engaged)
Ben.So.Tex
08-25-2002 14:15:09
I just bought a 720LP that has been setting awhile and the clutch is stuck in the engage position, How can I, are what I should do to unstick the froze clutch? When I pull back on the handle it comes way back and I dont want to damage anything. Thanks Ben..
scott AR
08-25-2002 15:43:48
 Re: My 1st 720//Clutch is stuck(engaged) in reply to Ben.So.Tex, 08-25-2002 14:15:09
I'm no JD expert and I'm hoping Clooney will jump in here and advise but I do have a 720 so I will tell you what I would do. You don't need to split this particular series as the clutch is inside the belt pulley in front of your right foot. Take off the end cover of the belt pulley, if it has one, remove three cotter pins in the adjustment bolts and loosen the castle nuts about a round. Rock the engine or the tractor a little then try to disengage the clutch again. If that is not enough go another round until it frees. Remember how much you changed the adjusting nuts as you may need to go back to where you were after you get it going. Are you sure the clutch is stuck and not the engine? Are you sure it is in the engaged position as some of those levers get a lot of slack in them and it's hard to tell where they are unless you are pulling something? I bet that Lone Star 720 is LP tambien.
Ben.So.Tex
08-25-2002 19:18:04
 Re: Re: My 1st 720//Clutch is stuck(engaged) in reply to scott AR, 08-25-2002 15:43:48
The engine is not stuck.The tractor has been setting awhile with no dust cover on the clutch. I will follow your way of trying to free it up. Thanks for the info.Scott and David and 430C/Have a good one BEN
David Ransom
08-25-2002 16:28:09
That sounds sort of like how I got the 50's clutch unstuck. I loosened those three nuts on the right end of the belt pulley. However, while there was and still is a bit of play in the lever, it would not go all the way back until I loosened those nuts. With the 50, the engine was stuck (one piston still is), meaning that when the tractor was in neutral, after the clutch got unstuck, the belt pulley could be turned by hand when the clutch was back, but the stuck engine held the pulley still when the clutch was forward.
tubba_JD420C_ny
08-25-2002 14:24:08
You might have to split the tractor. I have not experenced this myself, but I have heard of several times where this happened (on JD and other tractors) and each time the tractor had to be split in order to access the clutch to free it. Rust causes this to occur. Good luck with this.
