JD unstyled B
What color is axle??
JE
08-23-2002 17:20:20
I have a '35 B that I am restoring. I have seen pictures where the splined part of the axle is green, black or yellow. What color would original be? Thanks for the info!!
Clooney
08-23-2002 17:41:48
 Re: JD unstyled B - What color is axle?? in reply to JE, 08-23-2002 17:20:20
JE, if you want it original don't paint the axles. If you want the original look with rust protection use a clear coat. If you want a look that is accepted by most "experts" use a flat or semi-flat black. If [you] like the looks of yellow or green use that, it's your tractor.
Geoff
08-23-2002 23:04:35
 Re: Re: JD unstyled B - What color is axle?? in reply to Clooney, 08-23-2002 17:41:48
Clooney,
currently i am restoring a john deere 140 and i was wondering what brand of paint is the best, how many coats should i apply, drying time, and how much thinner should i use
