ID'ing a JD sickle mower
Bob G
08-23-2002 08:03:24
I purchase a sickle mower this week, haven't gotten it home yet. At first I thought it was a #5, but when I went to pay for it, it doesn't say what model it is. Is there somewhere on the mower that states which model it is? I will be bringing it home on Saturday so I will know more then.
Thanks,
Bob G
Bob G
08-26-2002 06:38:54
 Re: ID'ing a JD sickle mower in reply to Bob G, 08-23-2002 08:03:24
Thanks Guys,
It is a #5, It doesn't have a tag on it, but I remember what ours looked like at home. It has been sitting about 20 years, I will need to replace the pitman arm and bearing. I am going to put it on a Farmall M, it doesn't have a hitch, but I can build that.
Thanks again,
Bob G
JD Merl
08-23-2002 19:32:56
The #5 has a angle iron frame with gear box in the rear. # 8 has a channel iron frame with gear box in the center. Hope this helps !!!
POPPER DICK
08-23-2002 19:03:37
Bob,
I have a number 8 using a hydraulic lift mehanism. Mine has a model and serial number tag right on top of the sprocket housing assembly.
Hope thiss helps.
Dick
ChuckW
08-23-2002 08:33:38
as I recall the #5 had a mechanical lift setup, the number 8 had a hydraulic setup, both has the trailer wheels and drawbar mounts. There should be a name tag on the mower. Both mowers were good items in their day.
Craig-MN
08-24-2002 07:01:20
 Re: Re: ID'ing a JD sickle mower in reply to ChuckW, 08-23-2002 08:33:38
The #s 5, 8, and 38 mowers all had optional lift equipment. Could be hydraulic, cable, hand, rope,etc. The respective operators manuals show the lift options that were available for each mower.
