4630 engine knocking
Curt- from east
08-22-2002 19:45:15
A friend of mine has a 4630 and the engine will make a knocking noise only at just above PTO speed. I forget what the engine is running at when its at PTO speed but its like 200 RPM's above PTO speed it will knock really loudly and when you get above that its fine. It sounds completely normal below and above that speed and performance is not affected. I know he has the engine turned up a bit but I wouldnt think that that would cause that. I know that them 404's are puttin out enough hp already for their size and then to turn it up some more seems to be asking a lot of an engine that size.
geoff
08-24-2002 11:38:16
 Re: 4630 engine knocking in reply to Curt- from east central WI, 08-22-2002 19:45:15
check the hydraulic pump coupling
Gary Brady
08-23-2002 07:19:04
I believe Walt is right. It seems to be a common problem with the bushings in the front pump coupler. My 4020 sounded like it was about to throw a rod. The parts cost $7.50. If you have not replaced the alternator belt in a while it would be a good time to do it while you have the coupling off. Note that the bolts are threaded into the other half of the coupling and have a lock nut.
Best regards,
Gary Brady
walt
08-23-2002 06:45:28
Something to check for would be the hydraulic pump coupling at the front of the motor I have hade them come loose or maybe the rubber bushing have worn out.
mike
08-23-2002 20:43:13
 Re: Re: 4630 engine knocking in reply to walt, 08-23-2002 06:45:28
I had a friends 4630 engine with knock problem such as yours, found out it was injector line bent making engine knock, this may be your problem ,just thought it worth my two cents .
