John Deere Model L Serial 622405
Nate Lillibridg
08-22-2002 19:44:11
I recently purchased the above tractor from a relative farmer. It came with a land plow and a belly mowing machine. The wheel rims and motor are yellow while the remainder of the tractor is green. The motor needs work but the tin work is stright with a little rust here and there. I will be ordering a set of manuals; meanwhile, if anyone out there has any ideas or comments, feel free to send them along. Thanks, Nate
Dwayne Ridenour
08-23-2002 17:28:06
 Re: John Deere Model L Serial 622405 in reply to Nate Lillibridge, 08-22-2002 19:44:11
What you have is a 1938 unstyled L. If the motor is yellow, someone could have painted it or it might be the wrong engine. what it should have is a Hercules NXA series 2 cylinder engine. it will be stamped NXA on the mag side where the cylinder head meets the block there will also be a serial number (42???). The mower should be a bar type mower and not a rotary type. do a little scraping on the rest of the tractor and see if there is any yellow. Deere did paint a few of them yellow. it should have 22" rear tires the radiator should have JOHN DEERE embosed in the front. hope this will get you started, if you need to see pictures, go to my web page www.antiquejohndeere.com
