52 A governor dissasembly?
Jack
08-22-2002 14:05:15
I have been trying to free up my 52 A governor that had been setting for years.I got the governor off last night and got the weights free and the slider slides,but snugly.I wanted to get to the bearing on the spring side to take a gander at it.I took the linkage off the shaft that goes from top to bottom and can't figure out how the shaft with the gears comes out.Could someone enlighten me on this particular subject?Thanks.
Clooney
08-22-2002 15:31:13
 Re: 52 A governor dissasembly? in reply to Jack, 08-22-2002 14:05:15
Jack, if you have tried turning the weights so they are at the top & bottom & it still won't come out you will either have to reach in & remove the two screws & remove the fork from the shaft, or remove the external lever from the fork shaft so the shaft & fork can be turned so it will clear.
~Remember to keep the gaskets from the cover & fan tube attachment as they are really shims & control the gear position & backlash....
Jack
08-23-2002 14:54:12
 Re: Re: 52 A governor dissasembly? in reply to Clooney, 08-22-2002 15:31:13
I had to press that booger out but I got it.Thanks
