For Brian, more on baler
MIKE HANLEY
12-21-2003 07:02:16
I had some additioal thoughts on round balers that I would pass on. First you have to decied what the use is and then go from there. I'am talking about bells and whisels. Recall how I said in the other post about how it bales better at a slower ground speed with a BIG windrow rather then a faster ground speed with a small windrow. The key to making a good bale is to keep the pick-up of the baler full. With a 9' haybine, you have your small windrow and to keep the pick-up full you have to drive fast aqnd drive like a drunk and were always looking back. So the companies put electric monitors on the balers. Thats the first thing that will stop working. If you have a BIG windrow you keep the pick-up full, don't have to drive like a drunk and don't have to drive like you are in a race, don't have to look back as much. Nor do you need the monitor. If you run around the field 9' feet apart at a fast speed or if you drive around the field every 21' or 28' at a slower speed, at the end or the day it's about the same. As to the platic wrap,,,I have universtiy study after study that says, contray to the companies hupe, there is more spoilage with the plactic wrap then without when stored outside. The platic wrap trapps moisture IN the bale and also acts as a place to form condensation that puts MORE moisture into the bale. The companies answer to that (without admitting that the plactic was wrong) was the net wrap so the moisture can excape. That stuff is a pain to get off when it comes time to feed. The studys are still out on that. But for the add cost I think it does not pay. There maybe some advanage for a bale that get trucked across the country to keep the bale "LOOKING" good for sale,,, so the bale after a lot of handling it is still picture perfect. (But has nothing to do with the quilty inside the bale.) Dairy is differant then beef. Like I said before brood cows only need 1 1/2# of protien per day So for beef all you need is a plain jane baler and stored outside in a row on a slight slope. Those bales will thach and shed water the same way as the old big loose stacks did. As to feeding,,, the hipe is to have feeders so that every spear of hay is eaten and NONE hit the ground. OK. So we do that,,, well now we neen some bedding and maybe a barn,,,(Barn means, no sunshine, moistore builtup and vet bills.) Or we can feed outside right on the ground and the 10% that gets spead on the groung IS NOW BEDDING with a manure pack for warmth. NO BARN. NO ADDITIONAL BEDDING and sunshine. You do need a wind brake of some kind. We have woods covered coulee's for windbrackes. We don't have a barn, just a corral with a head gate and sorting pens. The rare times that a cow gets into trouble calfing in bad weather, we take a round bale, put it into the corral and then dig out the end of the bale. And put the calf into the holled out bale end. Water is there, feed is there, (the bale) shelter is there, (again the bale.) The headgate is there. In a couple of days when everthing is OK, we turn out the cow and calf and then take out what is left of the bale and let the cows go at it. No property taxes to pay on a barn. No insurance on a barn, no barn to paint. If you have any more questions you can E-mail me direct. [email protected] Got to go. Wife says we are late for church.
Brian
12-21-2003 18:32:49
 Re: For Brian, more on baler in reply to MIKE HANLEY, 12-21-2003 07:02:16
Mike Thanks alot, I really enjoy reading all your posts. Every time I drive through LaCrosse, I always wonder what it would be like to farm them thar' hills. I farm out in the plains of Iowa where a B will pull a full silage wagon from one end of the farm to the other without snorting and I have made a couple thousand round bales, all with twine, but I was wondering if a 70 has the horspower and the hydraulics to operate a 510 or Vermeer 605 baler? I really enjoy the freedom of having a simple 2 banger. Everytime I pulled my complicated 4430 in to JD it was $1500 easy. It's alot easier just buying the parts and saving the labor for the evening at home.
