JD 50 Oil Leak from Trans Belly
Gerry
08-22-2002 03:06:42
I just got this 50 about 2 months ago. This is all new to me. Did change all the fluids. Trans oil was the JD yellow paint... hi hi. Trying to park the thing without having to use all this card board to catch the leaking oil.
Have a leak coming from what appears to be a half inch freeze plug about 6-8 inches rear of the starter inspectiion cover. Just behind the drain plug. Did I over fill or what. And how do I go about replacing it or sealing it up. Thanks in advance.... Gerry.. NE Michigan..
Fudd
08-22-2002 07:10:09
 Re: JD 50 Oil Leak from Trans Belly in reply to Gerry, 08-22-2002 03:06:42
Mine leaked there too so I just sealed it with blue silicone. No problems so far after mowing hay with it.
Walt in Jaxn, Tn.
08-22-2002 19:08:01
 Re: Re: JD 50 Oil Leak from Trans Belly in reply to Fudd, 08-22-2002 07:10:09
my 50 leaked there also, water came out of mine, then finally rearend grease, yes it's a freeze plug or, rather a mold plug. i would think it could be replaced with a new one. i'd measure the one that's in it and go to a good parts house and see if i could get a replacement. if i could get one i'd remove the old one and install the new one. any good shade tree mechanic can tell you how to take the old one out and put the new one in. you might be able to strike the old one with a hammer and drift pin half the size of the hole and renew it's seal against the sholders of the hole.
