4020D Steering Problem
NWMO_Jim
10-17-2003 18:21:03
The steering is a bit flaky on my '69 4020D powershift. The steering wanders a bit, and there is a lot of play in the steering wheel. The service manual talks about 7.5 lugs (60 degrees) as normal, with an additional 3-4 lugs movement allowed with 15# rim pull, and then anything more suggesting air within the system. My steering wheel has unrestricted wheel movement with no effort of about 135 degrees (20 lugs), and then at the end of that range only 3-4 lugs movement with resistance before major resistance to movement.
Is this likely to be air in the system? I didn't have any tools with me when I was out at my tractor, so I haven't yet tried bleeding the system to see if it helps. What size and length tubing is needed to bleed the system, as I'll have to purchase a length of tubing to do this?
Thanks for your help.
david val
10-18-2003 02:14:58
 Re: 4020D Steering Problem in reply to NWMO_Jim, 10-17-2003 18:21:03
i daubt that the problem in your steering is air, but bleeding is the first step to take.
you need a transparent hose long enough to reach from the bleed screw to the transmission filler neck. you need the tech manual for the proper bleeding procedure.
david
jdemaris
10-17-2003 18:57:11
If you determine that the play is definetly hydraulic, and not from mechanical wear in the steering linkage, I doubt bleeding the sytem will help. More likely the steering valve either has internal leaks or is out of adjustment. There are four valves that are operated by actuating arms, all of which have adjusters on then not unlike those you'd use to adjust rocker-arms on the vavle train of an engine.
zane
10-17-2003 18:40:02
Check the mechanical linkage, especially the juncture of the steering arm atop the two spindle shafts. That bolt will work loose and allow the joint to wallow out.
