JOHN DEERE A OIL FILTER STUD
MICHAEL S
08-21-2002 06:31:02
I HAVE A JOHN DEERE A. THE STUD THAT COMES DOWN THROUGH THE OIL FILTER IS STRIPPED OUT UP INSIDE THE CAN. HOW DO I REPLACE IT? AND WHAT ELSE WILL I HAVE TO REPLACE? AND HOW DO I GET TO IT? ANY INFO WOULD BE APPRECIATED.
Dave K
08-22-2002 15:37:08
 Re: JOHN DEERE A OIL FILTER STUD in reply to MICHAEL S, 08-21-2002 06:31:02
You can work through the crankcase opening but it isn't easy. As you work with the oil lines you need to move the pistons around to be able to work on some of the oil lines. Better than taking the engine apart though. Did my 1948 Model A okay that way.
Jerry S
08-21-2002 10:38:21
I got a shop manual for a B from JD that was pretty helpful for me. I think it is SM2004 but would have to check for sure. In part, you will need to get a wire and bend it into a u shape and bend the ears of it inward to make a puller of it. I used a 5 gallon bucket handle for this job and it worked perfectly. That is to put into the holes on the side of that tube that sticks down around the bolt that stripped. You take a hammer and knock downward on your puller to get the tube out which exposes 3 bolts that hold the manifold that the oil lines hook to. Take all your oil lines loose before undoing the 3 bolts. If you can get by with it, you might be able to just switch the top half of the pressure regulator since that is where the threaded piece is. It would be nice if the bolt was stripped but the cast part it threads to was still ok. Once you get the canister all exposed, check it good to ensure it has a level top and isn't collapsed. If you have a crease in the top, it can keep your oil pressure low cause it doesn't seal up right. If it needs some minor bumping, you might be able to do it with a piece of wood either a round piece or a 2x4 would fit. If you beat too hard, your canister comes out then you have to pull that back down which isn't very fun. Once you have it all repaired, I believe it might help prevent the problem if you tighten the bolt to the oil pressure regulator then only remove the bottom cap to change oil filters rather than the stud coming out. Make sure your bolt hangs straight down when you are finished and I like to replace the rubber gasket around the filter cap so it seals easier. Only tighten enough to keep it from leaking.
Danny
08-21-2002 08:43:48
If the base is the part that is striped out, and I assume it is, I just replaced one on a 70. I was able to remove the crank case cover and work through it. Not an easy job, I did have to unhook one rod and push the piston forward to be able to undo the lines. I am unsure about being able to do this on an A. My book said you have to slide the block forward, but I was able to remove the base without sliding it. Hope you have good luck!
